American Standard Freedom 78 Issues. Please Help. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2009, 06:51 PM   #1
Question
American Standard Freedom 78 issues. Please help.
Hi,
About two weeks ago I came home to a freezing house (56 degrees). A little harsh when you're use to 78 degrees. I noticed that the furnace was running but only blowing out cold air since there was no flame. I then turned the furnace off and back on. The furnace turns on and within about 10 seconds you get a flame but after about 5 more seconds the flame is gone. I tried this several more times until it actually stayed burning. Sometimes it will stay lit right away, sometimes it takes a few trys on its own, but occasionally it will not light at all and blow cold air until you shut it off. This seems to happen 1-2 times a day.
I have no knowledge or experience with furnaces (besides changing the filter), but DO NOT want to resort to hiring somebody. If anybody can help I would greatly appreciate it.
Furnace: American Standard Freedom 78
Model: TXC025C4HPB1
Does not have a LED light
Do not have a manual
Thanks,
Kevin
kporter5414 is offline   Reply With Quote
Old 01-09-2009, 06:58 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 92
If it has a flame sensor clean it with emory paper. Should sit in front of one of the burners and look like one of these:
Old 10-20-2010, 07:14 AM   #3
furnace
Did you ever get this problem fixed? I'm having that exact issue and i am clueless where to even start?
Originally Posted by kporter5414 View Post
hi,
about two weeks ago i came home to a freezing house (56 degrees). A little harsh when you're use to 78 degrees. I noticed that the furnace was running but only blowing out cold air since there was no flame. I then turned the furnace off and back on. The furnace turns on and within about 10 seconds you get a flame but after about 5 more seconds the flame is gone. I tried this several more times until it actually stayed burning. Sometimes it will stay lit right away, sometimes it takes a few trys on its own, but occasionally it will not light at all and blow cold air until you shut it off. This seems to happen 1-2 times a day.
I have no knowledge or experience with furnaces (besides changing the filter), but do not want to resort to hiring somebody. If anybody can help i would greatly appreciate it.
Furnace: American standard freedom 78
model: Txc025c4hpb1
does not have a led light
do not have a manual
thanks,
kevin
greendogg is offline   Reply With Quote
Old 02-20-2015, 09:57 PM   #4
Rewards Points: 4
HI i have an AMERICAN STANDARD Freedom 78 unit and the furnance is set correctly and blowing cold air all the time unless I turn the unit off. The led indicator is flashing fast (steady not stopping) red light. I hear the unit clicking but I don't see the pilot light burning or and the burners won't light. Thanks for any helpful information.
Morrislp is offline   Reply With Quote
Old 02-21-2015, 11:28 AM   #5
Rewards Points: 4
American Standard Freedom 78 furnace pilot light not lighting
I have an American Standard Freedom 78 Furnace blows cold air all the time and tries to light the pilot but just clicks. The thermostat is set correctly and is on the Auto setting. What is the most problem with my unit?
Thanks,
Tags
american , freedom , standard
American Standard Freedom 90 Question bobjbc HVAC 22 01-04-2016 04:51 PM
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-08-2011 11:33 PM
American Standard Freedom 80 troubles johnmax HVAC 1 11-26-2008 12:43 AM
american standard freedom 80 KEITH112 HVAC 5 11-12-2008 12:20 AM
