Old 12-10-2010, 08:59 AM   #1
American standard Draft inducer noise
I have a 5yr old freedom 80. Sometimes it seems like my draft inducer makes a whining almost squealing when running then stops. It almost sounds faintly like a circular saw cutting through wood very faintly though. Could this be the motor or the bearing.Or do you have to replace them both and is it hard to do it looks pretty straight forward
Jeff
jprince is offline   Reply With Quote
Old 12-10-2010, 12:11 PM   #2
HVAC / Plumbing
Could be bearing or squirrel cage (blower wheel). If you replace. Replace the entire assy
kenmac is offline   Reply With Quote
Old 12-10-2010, 05:04 PM   #3
Hard to find here:
http://www.fasco.com/documents/fascopage51-59.pdf
under Amer Standard
but...
http://www.furnaceparts.com/Store/Product/A195.aspx
resulted in search on AS. Might be an 'A195'? Study pic carefully.
Maybe verify by pic & specs and then place to buy from?
diyorpay is offline   Reply With Quote
Old 01-24-2011, 10:38 AM   #4
Originally Posted by diyorpay View Post
Hard to find here:
under Amer Standard
but...
Just gave the OK for a new inducer to be installed. $650 just for the blower. The link above shows it for $134.75. Man, that's some markup.
3echo9 is offline   Reply With Quote
70-24157-03 Rheem Draft Inducer Noise jjdegra HVAC 3 02-21-2010 08:32 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Godman, Lennox, or American Standard homeowner12 HVAC 2 10-13-2009 06:54 AM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 03:10 PM
New Rheem 90+ is making a strange noise. Draft inducer? shinkansen HVAC 1 01-09-2009 09:38 AM
