American Standard Boiler Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 08:16 PM   #1
Rewards Points: 150
american standard boiler problem
i have a very old american standard boiler. its all rusty. looks like its fifty years +. the serial number doesnt seem to indicate a year. its something like 7B... with some other numbers after. 131,250 btu. in the back right above the intake manifold there is a rectangular hole. like maybe a sediment clean out or something. it looks like there should be a plate with a rubber gasket over it or something. it is missing. there are no screw holes, so it must have been attached with some kind of clip/screw assembly. when i try to fill the boiler the water comes right out of this hole. is there anyway to find a replacement part for this?
drewhart is offline   Reply With Quote
Old 01-14-2009, 08:20 PM   #2
JohnH1's Avatar
There is more to this story. Have you has heat this year? Or new property to you . The opening is probly a spot for a tankless water heater.
JohnH1 is offline   Reply With Quote
Old 01-14-2009, 08:23 PM   #3
Rewards Points: 150
i have not had heat this year. it is new property to me. its never been turned on since ive had it. it looks like some work was done on the lines, but nothing to the boiler. it looks like it was made of rust. tell me more about this tankless water heater idea.
Old 01-14-2009, 09:28 PM   #4
JohnH1's Avatar
It is a coil you insert into the boiler to allow the boiler to heat the domestic water instead of a water heater. By the sounds of it, Time for a new boiler American Std. has not been made for years. Crap is crap
Old 01-14-2009, 10:37 PM   #5
Rewards Points: 150
it is crap. although crap can be warm...and steamy.
Old 01-14-2009, 11:00 PM   #6
JohnH1's Avatar
This is true but with heat you also want safe and dependable. But most anything can be fixed. Just keep in mind if you invest a lot in this. That could be a good down on a new one.
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-09-2011 12:33 AM
compare Goodman Furances to American Standard Furance ymhdj HVAC 1 07-23-2008 06:53 PM
American Standard Freedom 80 furnace weather_wolf HVAC 2 03-30-2008 09:50 PM
American Standard freedom 90 3 flash code t_cel HVAC 1 12-23-2007 06:38 PM
