American Standard AUX120C960D2 Parts? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 10:54 PM   #16
Originally Posted by hvactech126
yes, too little amp draw
Working on a ptac back pressure is 40lb head pressure is 130 r22 was weighed in to specs,delta t across evap is 25-28 f the main problem is the filter drier leaving the compressor to the condenser is icing (first time for me) seems like the liquid is not boiling at evap therefore getting flood back at compressor still don't get the icing. Any suggestions?
Zuna316 is offline   Reply With Quote
Old 10-18-2011, 10:58 PM   #17
I forgot to mention that someone replaced a 12 ton comp. With a 15 ton. Am sure that could very well be the problem
Old 10-18-2011, 11:12 PM   #18
What do you suggest I was thinking of putting smaller compressor
Old 10-18-2011, 11:20 PM   #19
Well two things..
It is better to start your own thread.
The drier should have been changed when the compressor was replaced. Are you sure about that compressor size?? That's a hell of a ptac at 12 tons.
Master of Cold is offline   Reply With Quote
Old 10-19-2011, 08:10 AM   #20
Thanks for all the advice. As I know some folks that work at Grainger (as their HQ is here) I can get a good discount.
I did a quick look and it looks like this would work. I did notice that it was listed as a 5 spd vs. a 4 spd.
http://www.grainger.com/Grainger/wwg...N=0&sst=subset
Thanks...
j_internet is offline   Reply With Quote
Old 10-19-2011, 04:28 PM   #21
Rewards Points: 77
Get me your exact model , I'll get you info on motor and may be able to email parts breakdown
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Old 10-19-2011, 04:42 PM   #22
Rewards Points: 77
MOT08842 3/4 hp , 1100rpm , 115 v , 48 frame
Old 10-19-2011, 05:14 PM   #23
Thanks that can help. A breakdown would be good. Or if I can order the part direct. Is this something that you can service and sell? PM me or let me know how to get in contact.
Thanks!
Old 10-22-2011, 11:14 AM   #24
I did some more testing with the original motor in the unit. It is pulling close to 16 amps (15.4) on startup and running around 7.8 amp. This looks a bit high and the reason I am looking to replace is the large draw/hum at startup.
Thoughts if I am going down the right road?
Thanks Again!!
Old 10-22-2011, 04:00 PM   #25
AKA HVACTECHFW
Rewards Points: 1,208
check the capacitor.... A weak cap will cause a hum and high startup amps.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-22-2011, 05:26 PM   #26
Hi ,
thanks for that advice. I did replace the capacitor as I thoguht tht might be the issue and was the cheap fix. After a new cap the current amp draw and hum is the same as before.
So I am guessing the motor is next? just want to make sure before I order one.
Thanks.
Old 10-22-2011, 05:51 PM   #27
You can change the cap and buy some time. But you will be looking at a motor soon. Might be next week, might be next month. No way to tell...
Gas furnace brands, which is better, Comfortmaker, American Standard, and Lennox? abefroman HVAC 10 04-22-2014 06:03 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
American Standard Freedom 90 Operation Question goodtexan HVAC 1 01-31-2010 05:01 PM
American Standard Furnace Mystery David6 HVAC 37 01-30-2010 09:50 AM
Godman, Lennox, or American Standard homeowner12 HVAC 2 10-13-2009 05:54 AM
