American Standard 5000 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2014, 08:53 PM   #1
American Standard 5000 furnace
Furnace works fine for a while but then unexpectedly stops. when checked I get red light blinking 2 times. furnace was bought in 1989-1990.When the power is turned off and back on, it works fine for weeks. it has happened two days in a row this week.
mandtfoster is offline   Reply With Quote
Old 02-07-2014, 09:39 PM   #2
how
Rewards Points: 1,070
Somewhere on the furnace will be a legend to show you what those flashes mean.
how is offline   Reply With Quote
Old 02-07-2014, 09:49 PM   #3
Rewards Points: 582
sounds like flame sensor ....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
hvactech126 (02-08-2014)
Old 02-07-2014, 09:50 PM   #4
Rewards Points: 16
Sounds like the Hot surface igniter may be bad, found same question on another website and they said tech replaced the hsi.
This is what it looks like http://www.amazon.com/FURNACE-REPLAC.../dp/B0092PZ8S8. Not saying this is yours
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 02-08-2014, 11:36 AM   #5
AKA HVACTECHFW
Rewards Points: 1,208
multiple possibilities for "ignition lock out" - flame sensor needs cleaned or the HSI is not getting hot enough to light the gas, or the gas valve is not opening, or the gas if off or there is no gas.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
ben's plumbing (02-08-2014)
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 10:13 PM
american standard furnace casino1a HVAC 1 08-05-2011 01:36 AM
American Standard Freedom 80 Furnace Jepierson HVAC 1 07-06-2011 06:22 PM
Godman, Lennox, or American Standard homeowner12 HVAC 2 10-13-2009 06:54 AM
