#1 |
America Standard Freedom 80 furnace problem
Hello there,
I have a 6 years old America Standard Freedom 80 (downflow). It has started acting up lately. When it calls for heat, it blows cold air only. It doesn't light up. The red LED flashes 3 times when in trouble. It happened several times in last few weeks. However, it works again if I turn off, wait for approx 10 minutes or so, and turn on. Once it works normal, it goes for 2-3 days, or half day. It's anyone's guess. I don't know how long it would work again by doing this on/off. The local energy provider tech visited but couldn't find a problem. After a few checks including turning on/off, it started running. He suggested to change the circuit board if it happens again. two things to note. (1) I have the duck and blower cleaned this summer. The guy took the ciruit board apart, cleaned the blower and put all back together. I wonder if this current problem is related with that(maybe wiring mistake???), because it was running well last year and he is the only one who touched the circuit board. (2) When the furnace doesn't work, the electronic ignition stays unchanged while it changes red (hot, igniting) when the furnace works. Would anybody advise on this problem? I'll appreciate it. Last edited by kim98109; 11-27-2007 at 12:46 PM. |
#2 |
Thoroughbred Mopar Man
Hi kim98109
And they say you cant stop a Trane. It sounds like to me you are having a problem with either a limit trip or an ignition proof failure. The unfortunate thing about American Standard/Trane equipment. Is that you cannot tell by the blower running which one has happened. They are still trying to get out of the dark ages as far as their electronics are concerned. Either way I would have the servicing company come look at it if you are not mechanically inclined. Both are going to require some dismantling of the furnace. Let me know and I will try and walk you through the process. Good luck Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character. |
#3 |
Dear Carrierman,
Thanks for your advise. I did web research to find what those 3 flashes on red LED means, and found the following. 3 Flashes --- Draft Pressure Error - Possible problems: a) Venting problem b) Pressure switch problem c) Inducer problem Anybody can confirm if this diagnosis is correct? Assuming correct, how your suggestion, limit trip or ignition proof failure is related with the above? Can you explain further? I just want to understand correctly. Thank you so much, kim98109 |
| Display Modes | |
| Heil Furnace Burner Problem | timothyr | HVAC | 78 | 01-18-2013 07:49 PM |
| 3 - flash code, american standard freedom 90 furnace | dfferg | HVAC | 25 | 03-05-2012 12:21 AM |
| New High Efficiency Furnace Problem | Buster 567 | HVAC | 8 | 12-13-2010 09:36 PM |
| furnace problem | captjack | HVAC | 8 | 11-23-2007 12:15 PM |
| another question for a miller furnace problem | jb9270 | HVAC | 1 | 02-05-2007 03:04 PM |
