Amanda Furnance Fan Off Balance? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 09:59 AM   #1
amanda furnance fan off balance?
this sound has been going on for the past 2 weeks and getting progressively worse. I'm no HVAC guy buy I can handle working around voltage to fix it myself. Sounds to me like a fan striking metal during its revolution.
The video starts after i powered off the furnace from the thermostat. Sorry for the groan at the end :P
Any ideas?
donbondave is offline   Reply With Quote
Old 01-24-2010, 10:06 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
Remove the doors, sounds like your squirrel cage wheel in the main blower is broken and hitting the body and needs replacing. Try spin it by hand and move it side to side. One of the motor mount brackets may be broken also. You really need to remove the whole fan to find out.
Old 01-24-2010, 10:08 AM   #3
HVAC Tech/ Browns Fan
Yes you have a noise but it can be draft motor , fan motor or something in side fan wheel. Take the covers off and hold down the service switch and hear it that way.
Tator1076 is offline   Reply With Quote
Old 01-24-2010, 12:15 PM   #4
Time for a new wheel. How old is the furnace and whats your warranty say?
SKIP4661 is offline   Reply With Quote
Old 01-24-2010, 01:46 PM   #5
cover off, you can see which part is making the noise, not sure how to go about finding the parts for replacement in a timely fashion. I guess a HVAC supply place...
second video is the culprit, and attached pic is the model details.
Old 01-24-2010, 02:01 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 396
That fan is called a inducer fan or ventor fan. May have a 5 yr warranty. Check with the installer or a Amana dealer. Labor not covered.
Old 01-24-2010, 02:41 PM   #7
You could try pulling the vent off and see if there is something in there.
Old 01-25-2010, 08:45 AM   #8
so i yanked everything apart. The impeller was warped to all hell causing vibration which was noisy. The assembly is similar to a turbo charger on a car. I bent the impeller back into place to get me though last night and tonight, and ordered part 0131m00002s for $133 which replaces part b4059001.
I'm going to call this "fixed", but will update if things change. Thanks for your help!
Furnance question. diy4life Building & Construction 29 12-01-2009 05:39 PM
Furnance question satz HVAC 8 02-05-2009 07:44 AM
Furnance burner won't stay on. 2007ken HVAC 11 03-03-2008 11:29 PM
Attic Ventilation - importance of balance FatAugie Roofing/Siding 7 08-04-2007 10:57 AM
