Amana Natural Gas Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 01:54 PM   #1
amana natural gas furnace problem
Every 6 months the tech comes and "cleans" the AC or the furnace to get it to work.
I hope to do it myself if I can.
So the power is on at the furnace , I turned the side switch on / off and heard a click near the control board in furnace.
The gas valve is also on. The fan comes on if thermostat set in on mode, but in auto mode it doesnt start.
The control board has a few wires and some instructions but no LED lights. I couldnt find the igniter (dont know if its electric or pilot light)
Help !
chadisbad13 is offline   Reply With Quote
Old 09-25-2012, 02:52 PM   #2
Rewards Points: 610
1st check to see if thermostat is set to "heat" mode..then make sure the set temperature on thermostat is above room temp by at least 2 degrees..furnace switch in "on" position ...the furnace should then start.. if not let us know what is happening and make and model and post pics if possible then maybe we can help
techpappy is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
Furnace Problem JASPER2008 HVAC 9 11-22-2008 08:54 PM
