Amana Gas Furnace No Heat LED Blinks 4 Times - HVAC - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 11:16 PM   #1
Amana Gas Furnace no heat LED blinks 4 times
So we are in the shoulder season here in Georgia where we jump from a little A/C in the daytime and occasionally have the need for heat at night. The other day we noticed that the air coming out of the vents with A/C on smelled a little musty. It was not not quite like dirty socks but not quite like fresh conditioned air either.
I suspected the coil to be moldy or mildewed so I inspected it and it looked fine. I sprayed some coil cleaner on it just for the heck of it. Later that night we turned the heat on and the burners never lit. So we had stinky air with A/C on and no heat.
When calling for heat, the circulator blower continued to run and the induced draft blower never ran. After it cycled, the LED was blinking 4 times. The code is for an open primary or auxiliary circuit. The upstairs furnace is working great so I tried swapping the switches into the non-heat unit. No resolution. I then swapped the integrated circuit board. No resolution.
I have recently replaced very dirty filters. I do notice lower circulator blower output through the vents. When the A/C is on the air coming out of the vents smells and the speed and volume seems less than the working units vents. I can't see or feel of any blockages in the air inlets. I am thinking about swapping the circulator blower to see if that is the issue. Any thoughts?
rust101 is offline   Reply With Quote
Old 04-14-2013, 05:03 AM   #2
An old Tradesmen
Rewards Points: 7,826
Probably a dirty A/C coil. need to look at the side where the air blows into the coil.
Old 04-14-2013, 09:20 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 180
some units and especially Amana/Goodman have an extra auxillary limit control which is mounted on the backside of the fan housing or on the deck below the burners but in the fan compartment B4 the fan. it may be open or you got bad connections in one of the wiring harnesses. may have a manual red reset button on it.
Tags
4 blinks , 4 flashes , auxiliary circuit , no heat , primary circuit
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 07:48 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Carrier Gas Furnace 92 Comfort-No heat. rmjr77 HVAC 4 01-20-2010 03:14 PM
