Old 12-14-2008, 05:38 PM   #1
Amana Furnace Won't Light
I have an Amana Furnace Model #GUIC070FA30 that was installed in 2004. For some reason it will occaisionally ignore the thermostat and stay off. I know it's not the thermostat because when I crossed the red and white wire, the furnace stayed off. I shut everything off and back on, then it works. After a few days, the same thing happens. Any ideas? Thanks in advance!
fking29@gmail.com
fking29 is offline   Reply With Quote
Old 12-15-2008, 01:07 AM   #2
Clean the flame sensor and see if it helps.
SKIP4661 is offline   Reply With Quote
Old 12-15-2008, 06:30 AM   #3
An old Tradesmen
Look at the error code, and see what error its giving you.
Old 12-15-2008, 05:17 PM   #4
Thanks for the advice. The indicator light was on continuously so I figured it must be the control board. This morning my house was 60 degrees again so I shut the furnace off for 5 min and back on and it worked. I called the HVAC company that installed the furnace 4 years ago and they came out. The first guy said the furnace was just dusty, so he cleaned it, and 6 hours later the problem came back. I convinced the second guy to replace the control board since it was under warranty. Now I have my fingers crossed!
Old 12-15-2008, 05:39 PM   #5
An old Tradesmen
Well.
If it quits again tonight, or tomorrow.
Check the error code.
Then when the tech comes back, see if what he says was wrong. Coinsides with the error.
Tags
amana, furnace, won't start
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 05:27 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
Furnace won't light Babybird HVAC 2 03-30-2007 10:48 AM
