-   -   Amana Furnace Won't Light (http://www.diychatroom.com/f17/amana-furnace-wont-light-33748/)
fking29 12-14-2008 04:38 PM
I have an Amana Furnace Model #GUIC070FA30 that was installed in 2004. For some reason it will occaisionally ignore the thermostat and stay off. I know it's not the thermostat because when I crossed the red and white wire, the furnace stayed off. I shut everything off and back on, then it works. After a few days, the same thing happens. Any ideas? Thanks in advance!:)
fking29@gmail.com
SKIP4661 12-15-2008 12:07 AM
Clean the flame sensor and see if it helps.
beenthere 12-15-2008 05:30 AM
Look at the error code, and see what error its giving you.
fking29 12-15-2008 04:17 PM
Thanks for the advice!
Thanks for the advice. The indicator light was on continuously so I figured it must be the control board. This morning my house was 60 degrees again so I shut the furnace off for 5 min and back on and it worked. I called the HVAC company that installed the furnace 4 years ago and they came out. The first guy said the furnace was just dusty, so he cleaned it, and 6 hours later the problem came back. I convinced the second guy to replace the control board since it was under warranty. Now I have my fingers crossed!
beenthere 12-15-2008 04:39 PM
Well.
If it quits again tonight, or tomorrow.
Check the error code.
Then when the tech comes back, see if what he says was wrong. Coinsides with the error.
