Am Std Freedom 90 Fan Runs Continuously With T Stat Fan On Auto Heat/cool On Off - HVAC - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 12:13 PM   #1
Am Std Freedom 90 fan runs continuously with T Stat fan on auto heat/cool on off
What would be the problem with the furnace if the blower stays on even with the T Stat on auto and heat/cool on off? I get a continuous green flash and 1 red flash every 20 seconds.
lmdaplumber is offline   Reply With Quote
Old 03-11-2012, 12:23 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
First I would say check the code chart on the furnace to determine what the flash code means.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-11-2012, 12:28 PM   #3
Flash codes are missing
the flash codes are not legible
Old 03-11-2012, 12:59 PM   #4
Rewards Points: 560
You can forget the red LED it is a Liteport
The Green LED flashes slow = Normal operation No call for heat
The Green LED flashes fast = Call for heat
If you can remove the thermostat from it's base...Does the fan stop running"
If yes then replace the thermostat
If no then remove the panel from the furnace and remove the wire connected at the terminal block "G". Either install the panels or hold in the safety switch and does the fan run?
Old 03-11-2012, 01:25 PM   #5
how
Rewards Points: 1,104
If removing the thermostat "G" wire on the board does not stop the fan then it's time to check if any of the limit controls on the furnace are open? (power to one side only)
If they are all OK then a stuck fan relay would be the suspect.
how is offline   Reply With Quote
New Honeywell RTH2510 - A/C continuously runs. kloiga HVAC 27 12-29-2011 07:35 PM
American standard gas furnace installed in 2006, fan runs continuously alfred franklin HVAC 2 01-04-2011 10:51 AM
honeywell furnace/ac blower runs continuously not heat or ac grnded HVAC 1 05-30-2010 05:18 AM
AC Unit Continuously Runs - yet it is cooling reefland HVAC 4 06-17-2007 07:04 PM
Blower fan runs continuously mgeller HVAC 5 04-19-2007 09:27 PM
