Am. Standard Control Board - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 09:31 PM   #1
am. standard control board
I installed a new board on model adx080c942c1. The old board was burn"t due to a shorted hi limit. The xmr. was burn"t also. Replaced xmr. installed factory hi limit along with new board. I now have a fault code of flame sensed with no flame.( five flashes) I don't understand how this could be or how to clear it. I tried two new boards and still the same. Please help.
bmwcomhom is offline   Reply With Quote
Old 10-17-2011, 09:35 PM   #2
JJboy's Avatar
You need to clean the flame sensor with steel wool
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-17-2011, 11:05 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
no, that is not it. DID you use an oem board or a aftermarket board? You either have something miswired or you have the wrong board.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-19-2011, 10:32 PM   #4
this was non oem board. did not receive the jumper wire packet. the board needed a jumper from rollout output to roll out input. universal board causing universal lesson. always read the small print. thanks for the input.
Trane XE90 control board dead? phatsupratt HVAC 4 09-24-2011 07:30 PM
blower control board ferawhile HVAC 0 04-14-2011 11:57 AM
nexxt 500 WFMC3301UC motor control board nate008 Appliances 3 04-21-2010 09:34 PM
Well Pump wiring with standard control box plumbdoc Plumbing 8 02-04-2010 10:27 PM
HELP? Control Board Fixed Heat...But Now A/C Won't Turn On - Homeowner KLR HVAC 35 08-15-2009 11:46 AM
