Aluminum Vs Copper For Compression Fitting - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2009, 01:32 PM   #1
aluminum vs copper for compression fitting
In general is there a difference in using 1/4 inch copper or aluminum tube for a gas compression fitting? does the aluminum sqeeze to make a better flare? or does it matter?
thx
pnutzhome is offline   Reply With Quote
Old 03-19-2009, 02:11 PM   #2
RippySkippy's Avatar
Are you asking about a compression OR flare type fitting...they are different and are not used interchangeably. What's your application?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 03-19-2009, 02:14 PM   #3
compression fitting
Old 03-19-2009, 02:16 PM   #4
Remodeling Contractor
What is your application... . what are you using it for...it's purpose... not what fitting.
Old 03-19-2009, 02:44 PM   #5
I just mean in general terms... is the aluminum used because it is cheaper or easier to use. I think water heaters use aluminum
Old 03-19-2009, 03:49 PM   #6
An old Tradesmen
Rewards Points: 7,414
Aluminum is used, because the manufacturer of the unit doesn't know if its going to be installed in a certified acid free area system. Or an area that the gas still contains acid vapor.
The Hydrogen sulfide acid, in natural gas eats copper but has little to no effect on aluminum.
Old 03-19-2009, 04:09 PM   #7
An old Tradesmen
Plus, its also cheaper then copper.
Old 03-19-2009, 04:14 PM   #8
That's why a lot of buried copper lines (In chases) were over sized by one size.
but Now i only run black pipe inside for appliance supply lines. I terminate them with a stainless flex connector.
hvaclover is offline   Reply With Quote
adding copper pigtails to my aluminum wiring was worth it ntomlin Electrical 7 03-02-2009 11:20 AM
Aluminum to Copper Leenders Electrical 4 08-21-2006 07:54 AM
copper verses aluminum for 50 amp circuit wiggs Electrical 7 04-15-2006 05:25 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
