Alternatives For Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 05-09-2013, 12:11 PM   #1
alternatives for insulation
I have a 10x20 build out back and i want to insulate it but the cost to insulate it is out of my price range. What i was thinking was maybe if i got some thick covers or blankets and staple them to the walls and ceiling that might work idk.. i wont to get it insulated so an run my window AC and it keep it cool no problem..
So does nyone have Any sugestions on insulating my uilding without buying insulation
itsmyyname is offline   Reply With Quote
Old 05-09-2013, 05:40 PM   #2
Special User
Rewards Points: 1,230
Does your building have drywall covering the walls and ceiling? If so, drywall has some insulating value on it's own and your A/C may be able to keep up with the heat.
If you have bare studs/joists then just putting up a plastic vapor barrier will work better than blankets. Plastic keeps the hot and cool air from mixing.
Make sure your building attic is sealed off from the interior and that the attic is well ventilated. It should have soffit vents and ridge vents so hot attic air rises out the top and cooler air is drawn into the eaves. (Gable vents are useless unless the wind is blowing the right direction.)
Some say a radiant barrier against the underside of the roof deck helps... stuff's probably about as expensive as insulation though.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 05-09-2013, 05:46 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
If you can't afford insulation, I'm at a loss as to how you think covers or blankets are going to be cheaper.
One other issue....insulation is typically fiberglass....does not burn....covers and blankets? BIG fire hazard.
ddawg16 is online now   Reply With Quote
Old 05-09-2013, 10:49 PM   #4
Rewards Points: 216
in the long run, insulation will cost less.
Fix'n it is offline   Reply With Quote
Old 05-10-2013, 08:10 PM   #5
Dog hair from the groomers? Drier lint? Cattail fuzz?
Sorry,couldn't resist.
Alternatives to Azek? CareBear Building & Construction 5 07-31-2012 05:12 AM
PT Wood end treatment - no one local carries it, alternatives? Quicksmoke Building & Construction 9 04-19-2012 08:03 PM
Alternatives to formica? roasted General DIY Discussions 11 01-26-2012 07:29 PM
Vent Routing / Alternatives? psilva8 Plumbing 5 01-13-2012 11:13 PM
Alternatives to using wood structural members in a brick building vvzz Building & Construction 5 05-03-2011 07:52 PM
