Alternative To Range Hood Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 12:00 AM   #1
Rewards Points: 462
Alternative to range hood fan
Hello all,
I am building a custom kitchen for my new home and I would like to have a cabinet enclosed range hood as opposed the standard under cabinet range hoods. These are quite expensive and I don't need something quite so high end.
I was considering the possibility of making my own range hood using a bathroom fan and a couple can lights mounted to a piece of wood recessed in the underside of the cabinet. One particular bathroom fan I found perfectly fits a range hood filter behind its screen.
Problem is, most range hoods are 150 CFM and greater while most bathroom fans are 120 CFM and under.
My other thought is to butcher up an economy range hood just to get the fan housing out of the center, but of course that is all welded together so it sounds like a lot of work with a hacksaw and tin snips.
Can anyone offer any suggestions for what might work for such a project?
Richo is offline   Reply With Quote
Old 04-09-2010, 08:21 PM   #2
Remodeling Contractor
buy a fantec fan. these mount in the attic and only the intake vent goes into the kitchen
Old 04-11-2010, 02:43 PM   #3
I would think a microwave oven between the cabinet and range would be the way to go, maybe that wont work for you. Another possibility is to install a wall stack and cut out an opening for/a grill that could accommodate for the appropriate filter. Then install the motor and venting in the attic or crawl space.
Flashheatingand is offline   Reply With Quote
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Installing Range Hood and Stainless Steel Backsplash oguevarra Remodeling 1 02-26-2010 04:01 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
Installing a range hood NewHandyman Electrical 1 08-10-2009 09:42 AM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
