Are All Classic "round" Honeywell Therms Low Voltage? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2009, 08:13 PM   #1
Question
are all classic "round" Honeywell therms low voltage?
I have some electric baseboard heating units that are controlled by one of those round classic Honeywell thermostats. It's doesn't have the fan/ac switches. I want to replace it with a digital programmable unit.
Can't pull it off the wall right now, but wondering if it's even possible that this classic round design is switching the voltage to the heaters directly? More likely I think it's standard 24v low voltage controlling a relay somewhere.
Is there a classic round Honeywell thermostat even made to switch 240 volts directly? Or am I ok in ordering an new 24v thermostat to replace it?
thanks for any hints!
nykije is offline   Reply With Quote
Old 11-17-2009, 08:55 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
There were/are a few square 110 volt Honeywell tstats that break one leg of a 220 circuit but I have never seen a round one for that job. Most likely 24 volt but you need to find the power source and make sure. Pop the cover off of the tstat, if it has a mercury bulb it is 24 volt and should say T86.
Old 11-18-2009, 07:33 AM   #3
Remodeling Contractor
no.. The main reason is the line voltage must be concealed in the junction box which is rectangular.
Tags
honeywell round therm
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
