Old 09-12-2010, 12:27 PM   #1
Al. mesh filters
I have a Lifebreath 195dcs (hrv) with duel cores. There two al. wire mesh filters, one at the inlet and one at exhaust. The filters are different thicknesses. The thin one has several mesh layers of the same mesh size. The thicker one has more layers that the thin one, but the mesh size deminishes as you look thru the filter. These filters are very similar to the ones you see in above-stove units. I would like to know which goes at which end. My thoughts are that the thicker one with the different size meshes would go at inlet, but I'm not sure. Anyone know for sure, or should I just use logic? Thanks
lottaair is offline   Reply With Quote
Old 09-13-2010, 06:34 PM   #2
An old Tradesmen
Al. mesh filters
See if the install instructions tell you.
If you don't have them. You can probably download them from their website.
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 48 05-14-2013 10:43 PM
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 10:09 PM
Repairing drywall seam after mesh showing hairline crack Genec Drywall & Plaster 7 07-20-2009 10:17 PM
2x2 mosaic w/paper mesh in shower gmbun Tiling, ceramics, marble 2 07-15-2009 05:13 PM
Furnace Filters rjordan392 HVAC 39 04-13-2009 12:40 PM
