Old 02-22-2011, 07:42 PM   #1
AIRE-FLOW Furness issues
Yes, - The house that my wife had bought needed a new furness and she had a, Aire-flow AF92 FURNESS PUT IN. - Now i would like to know what maint i can do or better yet, the first question is- is there more than one filter i need to change in it ? - Second i was talking with a furness repair guy at my work place about mine isnt heating up house like i think it should, and i told him about, that i found a big opening in the cold air ? ducting [air inlet ? ] and that i had just resealed up -[ could put arm all the way in]------ PRIOR to this repair, i was fixing the cellar door, and had it removed so i tacked up a blanket in door opening untill door is fixed.- Well then i noticed that when furness comes on it will suck that blanket in like a sail on a boat ,BIG TIME.- He said it sounds like a NEG PRESSURE from or with ? furness ???? not sure of what he means and so any info or suggestions would be great.
carl sheffield is offline   Reply With Quote
Old 02-22-2011, 08:51 PM   #2
Pull the blower out and clean the blower wheel and secondary heat exchanger. They are probably filthy with an open return in a cellar. A furnace usually has one filter but there's no way to know from here if yours has more. Search the forum for flame sensor. Needs to be cleaned once a year or so.
Old 02-23-2011, 11:28 AM   #3
Question
As i have never worked on a furness before do you think im capable of pulling and cleaning the blower, and the secondary heat exchanger ??- I DO HAVE FIXING CAPABILITIES AS im a tech at a local car dealership. for the last 29 years.---just got to know now where and what the secondary heat exchanger is. lol --- Im new to these home and house repaires, most of the time i dont know where to begin
Old 02-23-2011, 05:33 PM   #4
The secondary heat exchanger is the first part past the blower. If you can tear apart and repair a car then a furnace blower will be no problem.
Issues with junk tankless HWH. Need another solution viper Plumbing 2 10-10-2010 11:15 PM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 06:05 AM
Acid Neutralizer Issues Elamcup Plumbing 12 05-21-2010 09:09 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
