Aire-flo Blown Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 05:36 PM   #1
aire-flo blown motor
our a/c motor to aire-flo 12B42 blew last night. I know its owned by Lennox, should I use the Lennox name to look for parts?
Richardx3 is offline   Reply With Quote
Old 10-30-2010, 05:58 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
Try Cozyparts.com
The Following User Says Thank You to yuri For This Useful Post:
Richardx3 (10-30-2010)
Old 10-30-2010, 06:05 PM   #3
HVAC / Plumbing
If you have a local motor shop in the area. Thay should be able to match you up.
kenmac is offline   Reply With Quote
Old 10-30-2010, 06:32 PM   #4
air-flo blown motor
thanks for replies so quick- I (wife) have been online trying to find a place to get a new motor using the model name/number and havn't had luck. I'm going to stop looking for the exact part number, and look for replacement match. thanks to all of you
Old 10-30-2010, 06:39 PM   #5
Hvac Pro
yuri's Avatar
Phone Cozys, they can access it from Lennox.
Old 10-31-2010, 03:12 AM   #6
Lennox charges too much for their parts.
Match the RPM, amp draw, frame size and voltage off the old part and yiu will be able to find a motor replacement licitty split!
hvaclover is offline   Reply With Quote
New fan motor going out? DavidI HVAC 5 06-23-2010 10:38 AM
Air Handler Motor Wiring brando1118 HVAC 13 06-18-2010 11:42 AM
Oiling Trane XB1000 AC Fan Motor Build HVAC 5 06-19-2009 04:05 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
