Air Vent Under Bath Vanity - HVAC - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 11:17 PM   #1
air vent under bath vanity
This bath is in the center of the home, no exterior walls. Coming up from the foundation is a 4 inch plastic pipe acting as the air vent for the room. I wish to close this vent completely (simply cap it with a black rubber flexible pipe cap) in hopes of closing the vent and redirecting the air flow to other parts of the house. Currently, the air flow is very strong and has no vent cover. In the winter, when the heat is on, lotions and other products melt in the lower shelves of the vanity. Any reason not to use the rubber cap?
KSmelser is offline   Reply With Quote
Old 05-06-2012, 11:22 PM   #2
Rewards Points: 616
you will just have no air flow in the bathroom..... it should have a pipe damper in it and be installed in the kick plate of the vanity.... that's how its done here..... whats with the plastic pipe..... i am sure you will have more responses soon......
carmon is offline   Reply With Quote
Old 05-07-2012, 06:24 AM   #3
Rewards Points: 1,216
You need to install a diffuser in the kick plate of the vanity to channel the hot air out the front by your feet. You need to install a register boot to transition from the 4" pipe to a narrow register something like 31/2 " x 14".
COLDIRON is offline   Reply With Quote
Sewage line and vent design new basement bath JayRay Plumbing 8 02-04-2012 05:17 PM
bath vent location ? beachfront71 Plumbing 2 06-08-2011 08:40 PM
Vanity counter top question on Bath remodel cutiger58 Kitchen & Bath Remodeling 2 01-21-2011 10:02 AM
Will this bath vent routing work? Homerepairguy Kitchen & Bath Remodeling 5 01-05-2011 07:05 PM
Open Bean no Attic Bath Vent cdrusds HVAC 0 10-08-2009 04:46 PM
