Air Vent Leaking Next To A Skylight - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 05:46 PM   #1
Air vent leaking next to a skylight
We just bought a 10 year old house with a 1 year old AC system. There is a vent coming down the vertical column in the ceiling leading to the skylight in the dining room. I imagine this vent and duct get hot in the Houston sun - condensation. The vent drips water and the paint around it are stripped. Any solutions?
In addition, today I noticed some mold on the ceiling by an air vent in a bedroom extending into the vent.
ranger47 is offline   Reply With Quote
Old 09-09-2010, 06:16 PM   #2
HVAC / Plumbing
can you get to it to check the insulation around the boot or the lack of insulation around it
kenmac is offline   Reply With Quote
Old 09-09-2010, 06:24 PM   #3
Not sure I understand what boot you're talking about. Can you elaborate?
Thanks for helping!
Old 09-09-2010, 06:53 PM   #4
HVAC / Plumbing
It is what the supply pipe connects to. check the insulation on the pipe while u are there
Old 09-14-2010, 02:38 PM   #5
It appears it is forming on the inside of the register where there is really thin insulation. Can you buy just the insulation that goes inside the registrar (i.e. in the house)? If so, where? I looked at Lowe's and couldn't find it.
Dryer vent leaking imhotep Roofing/Siding 7 12-28-2011 04:54 PM
New roof, vent leaking livingmoon9 Carpentry 3 07-27-2009 08:17 AM
Ridge Vent Leaking 35thLE Roofing/Siding 5 01-08-2009 12:33 PM
Skylight leaking advice needed!Thanks Beeper29x Roofing/Siding 12 10-04-2005 09:53 PM
