Old 03-04-2012, 06:37 PM   #1
Question
Air Test Geothermal
I would like to air test the "field side" of my geothermal system including the heat pump for leaks.
What air P.S.I. should I apply,should that pressure hold indefinitely ,if not how long?
thanks,
tony
antonjh is offline   Reply With Quote
Old 03-04-2012, 06:56 PM   #2
GC/Master Plumber/Mech
Air Test Geothermal
Use water for you leak test.
You will find the smallest leaks alot easier
You can pressure it up to 60 psi with water easily
I always use water.
Keep in mind air will compress and expand the poly pipe where water won't compress and expand the pipe. And water can be seen where air can't. Water will test the whole system not just the joints and hundreds feet of pipe is hard to check with air.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
antonjh (03-04-2012)
Old 03-04-2012, 07:00 PM   #3
Air Test Geothermal
If you could take a pic of your loop field and post it. I would like to see it just out of curiosity.
Did you use loop or slinky loop in the field?
What brand system are you using?
Just curious?
Old 03-10-2012, 09:44 AM   #4
Air Test Geothermal
I am using a slinky loop and I purchased it from 1ST.Supply out of Madison Wi..
great price...
I am not sure if I have pic's.
Will be filling with anti-freeze mix from Wausau Chemical,also a great price.
I should have the heat up and running just in time for summer,ha,ha!!
Old 03-10-2012, 09:46 AM   #5
Air Test Geothermal
One more thing I installed 4-800feet slinky loops 7 feet underground,the trenches are 8 feet apart.
Old 03-10-2012, 10:28 AM   #6
Air Test Geothermal
So you have a 4 ton system?
Old 03-10-2012, 10:30 AM   #7
Air Test Geothermal
I have a Miami Heat Pump 5 ton water-to-water with Desuper Heater.
Radon test with 5pCi/L adgjqetuo HVAC 6 02-18-2012 08:52 PM
Geothermal recovery against house foundation dirtman HVAC 0 01-05-2011 02:54 PM
smoke test & combustion test?..what to look for?? millerheater HVAC 0 11-27-2010 11:44 PM
New test being conducted! Still hvac issue! MrShadetree0222 HVAC 24 10-21-2008 11:44 PM
