Air Source Heat Pump Lock-Out Control - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 10:48 AM   #1
When I had a 4 ton American Standard Heat Pump installed, we requested the HVAC contractor to intall lock-out control and set it at 35 degrees to get the rebate from local untility company. I asked the contractor numurous times about the Lock-out control number, but he has not provided the information. How can find out if I have a lock-out control intalled and if it was installed, where can I find the lockout control number?
Thank you.
Heidi
sydneysm is offline   Reply With Quote
Old 11-10-2010, 06:57 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
balance point stat
Their are many different types of controls available for this function. How old is the H/P? on older trane (American Standard) Heat pumps they were in the electrical panel of the h/p
hvactech126 is offline   Reply With Quote
Old 11-11-2010, 01:13 AM   #3
It's 2009 American Standard 4A6H604831(Heat Pump) and 4TEE3F49B1(Air Handler) that was installed about a month ago. Thermostat is Honeywell VisionPro Th8000 series. I was told by another HVAC specialist that I need to intall IAQ t-stat, which I am not sure what it is.
Thanks.
Old 11-11-2010, 04:36 AM   #4
An old Tradesmen
Rewards Points: 8,234
The TH8320 and TH8321 both can have an outdoor sensor installed. And then set to lock out your heat pump as you need.
Old 11-11-2010, 05:20 AM   #5
AKA HVACTECHFW
that stat should have an outdoor sensor attached, you can change the balance point in the installer setup
Old 11-11-2010, 10:26 AM   #6
Does it(outdoor sensor) have to be installed by HVAC contractor? I have a feeling that I am not going to hear from my contractor again and I am trying to keep the cost down by not hiring another contractor.
Thanks.
Heidi
Old 11-11-2010, 10:29 AM   #7
One more thing, how do I know if the outdoor sensor is attached and if it is, how do I change the balance point? Thanks.
Old 11-11-2010, 04:58 PM   #8
AKA HVACTECHFW
remove stat from subpanel, should have a s1 and s2 terminal if wires go to them, then it's most likely wired up. As far as changing the balance pint, you need the installers manual for the stat, it tells you which setup function and how to get in setup mode. This should be the installers guide you need, should be setup function 350. here's the link http://www.hydro-temp.com/help/drawi...069-1894ES.pdf
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 09:46 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 06:12 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
water source heat pump mountaineer HVAC 1 08-02-2007 05:47 PM
