Air Sealing Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 10:18 AM   #1
Rewards Points: 236
air sealing basement
all this talk about are sealing. thats great. but what if the furnace and HWH are in the basement. those need air.
please advise.
Fix'n it is offline   Reply With Quote
Old 04-05-2012, 10:47 AM   #2
the furnace has a high and low supply vent from the exterior the water heater does as well i believe.
cobra5laddict is offline   Reply With Quote
Old 04-05-2012, 11:14 AM   #3
Rewards Points: 236
not mine, that i can see. and i do know what i am looking at. both are under 6 years old.
Old 04-05-2012, 11:47 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
Pictures please.
Most do not need anymore air than already leaks into the home.
Many of the newer systems pull combustion air from outside.
If you have the home air sealed and insulated, you need to check drafting and for spillage if you are concerned.
Old 04-05-2012, 11:50 AM   #5
Rewards Points: 236
pics later. i have to go out now.
Old 04-05-2012, 05:41 PM   #6
Registered User
Rewards Points: 5,514
Did you ask your local AHJ?
Many of the codes vary by location and some change yearly. Example: "The minimum duct cross section dimension is 3”. (M1703.2.1 for oil and G2407.6 for gas)
�� No dampers in combustion air ducts. (M1701.3)
�� Sources of combustion air > 10’ from return air. (M1602)
�� Joist and/or stud space ducting ok only if a maximum of one fire stop is removed. (G2407.11)
�� Openings screened (except in attic) with 1/4” mesh. (M1703.5)
�� Opening sleeved to 6” above ceiling joists and insulation. (M1703.3 & G2407.11)
�� Combustion air obtained from outside of the building when the building is of unusually tight construction.
(M1701.1.1) (Typically homes built after 1986)
1. Minimum of 100 sq.in. per opening of combustion air is required.
2. One opening in upper 12” and one opening in lower 12” of room. (UMC 702.1, see exception)
3. Where vertical ducts are used each opening requires 1square inch per 4,000 Btu/h of total input
rating of all appliances in the space. (M1703.2.1)
4. Where horizontal ducts are used each opening requires 1 square inch per 2,000 Btu/h or total
input rating of all appliances in the space. (M1703.2.1)
5. When the one opening method is used. 12” from top of enclosure 1:3000 Btu/h or total input
rating al all appliances in the space. (G2407.6)"
If under the IRC: http://publicecodes.citation.com/ico..._17_sec001.htm
Gary
Old 04-05-2012, 06:15 PM   #7
Rewards Points: 236
what is an ahj ?
here are the pics. both units are about 7 years old.
i don't plan to heat the basement. except for a wood burning stove for when we are down there watching a movie or whatever. but i would like to air seal it so it acts as a buffer for the heat upstairs.
saying that, there is a space in a wall that goes up to the attic, about 4x12".
perhaps i could put ducts to pull air from the attic ?
excuse the mess. its under construction
Old 04-05-2012, 07:42 PM   #8
An old Tradesmen
Rewards Points: 7,304
Authority Having Jurisdiction.
Where is the wood stove gonna get its air from?
Generally, you seal p he basement. Enclose the water heater and furnace in their own room. And provide outside air for combustion to that room only.
Old 04-05-2012, 08:30 PM   #9
Read up on worst case depressurization and spillage.
Many homes that are sealed up quite tightly will still draft and vent quite comfortably.
If you are going to have a wood burning stove, I would suggest a direct vented unit and one that brings in its own combustion air.
Old 04-06-2012, 08:58 AM   #10
Rewards Points: 236
thanx, that is a good idea.
thanx. yeah, the stove would have its own in/out air system. and some kind of blower for the heat. i have seen/used 2 different fireplace/stove rooms. and for the small amount of wood they used, they heated the spaces very nicely.
Priming & Sealing Drywall in Basement nhoj Painting 31 02-28-2012 03:04 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
