Air Scoop Direction On A Hot Water Heating System - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 08:41 PM   #1
Air Scoop direction on a hot water heating system
Hi All,
I just had a new hot water heating system installed in my home and noticed that the arrow on the air scoop above the expansion tank is pointing in the opposite direction of the water flow. Although there doesn't appear to be any problems with the system so far, it's been running well for about a month now, is this acceptable?
Thanks.
mmcr179 is offline   Reply With Quote
Old 03-17-2010, 06:58 AM   #2
Joe F's Avatar
Rewards Points: 294
If this is something you recently paid to have installed, I'd make them come back and fix it.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 03-17-2010, 07:20 AM   #3
An old Tradesmen
Rewards Points: 6,498
Depends on the air scoop. Some are designed that if you install them backwards. The water flow isn't slowed long enough for them to work right. Others, it makes no difference.
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Desiging a manifold water system? BowDown Plumbing 1 07-20-2009 12:00 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
