Air Return Wall Grille - Slats In Which Direction? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 01:19 PM   #1
Question
Air return wall grille - slats in which direction?
We just had work done in our living room, and the large (a little over 1'Wx2'H) air return vent grille was removed. I just painted it to match the wall. The air return vent is in an upper corner of the living room wall, at the ceiling. (Our house is around 1970 vintage.)
The grille is metal and has angled slats. Should the slats be angled up toward the ceiling? Or down toward the room? Or doesn't it really matter?
Doitrite is offline   Reply With Quote
Old 02-06-2010, 02:18 PM   #2
An old Tradesmen
Rewards Points: 8,224
It doesn't matter except for aesthetics.
If you don't want to see inside the grille, point them up.
Old 02-06-2010, 05:51 PM   #3
Thanks, beenthere! I'm tired of looking at the hole in the wall and wanted to complete this weekend while we're snowed in!
Old 10-14-2010, 09:05 PM   #4
Regarding how the louvers should slant for your Supply or Air return on the Wall or Ceiling. There are several factors to consider. If you have an Air Return is on the upper wall I like to slant the louvers upwards so that floor traffic does not view into the duct opening. That is the same with Supply vents as well IF you have adequate air flow and few cold or hot spots in the room from inadequate air flow or distribution. I look at where the supply vents are located and try to set a circulation pattern in the room in order to minimize the hot or cold spots. Therefore, sometimes I recommend to slant the louvers left and right or Up or Down. Wood Vents give you the flexibility to set the angle of "throw", adjust the free air area or set up a good circulation pattern in the room. You can get a free evaluation from www.americanwoodvents.com .
americanwood is offline   Reply With Quote
Tags
air flow , grilles , hvac , vents
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
HVAC Return Grille - Primed for Paint janralix HVAC 3 06-09-2009 10:39 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
