Old 06-17-2012, 01:55 PM   #1
air return vents
as i was tearing out my basement i noticed what it looks like is 2 air returns. i went upstairs and i always knew i had 2 vents. i thought the smaller one was just a vent. i looked at it and realized it is just wall behind it. it isnt vented anywhere. the large vent is working correctly though. then i realized there is a vent near the celing. could that be a added return?
air return vents-img_2086.jpg   air return vents-img_2085.jpg   air return vents-img_2087.jpg
jhack836 is offline   Reply With Quote
Old 06-17-2012, 01:58 PM   #2
air return vents
i actually just took off the vents and the small one had cardboard over it! should i take the cardboard off and let it vent? also i just found out i desperatly need duct cleaning!!
Old 06-17-2012, 04:35 PM   #3
JJboy's Avatar
air return vents
You should insulate the ducts and seal the ducts joints.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-17-2012, 05:03 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
air return vents
There is no need, if they are in a basement.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 06-17-2012, 10:17 PM   #5
air return vents
ya everything is in the basement and easy access. half of the basement is insolated and the other half isnt because they had drywall over them so im guessing thats why they didnt. how much does duct work cost? i could tear the old stuff out and what not. everything is easy access in the basement on a 1 story ranch. i think i could even do it if the price is alot. otherwise i could get them cleaned but i heard that can be expensive
Old 06-17-2012, 10:27 PM   #6
gregzoll's Avatar
air return vents
There is no need to tear anything out. If you think that there are problems with duct sizing, etc, then you need to pay to have someone come in and assess the situation. Unless you know what you are doing, tearing into a already working or half-working system, without the knowledge, would just make things worst.
Old 06-17-2012, 11:08 PM   #7
air return vents
i hear what your saying. i do think it is undersized though. i think its the original
Old 06-18-2012, 08:33 AM   #8
gregzoll's Avatar
air return vents
If this was tract build, the contractor that built this home and others, could have cut corners, which is typical. If you get the duct sizing, equipment manufacturer & model #s, temp from the return at the furnace, temp at the farthest point, temp at the output at the furnace, temp at the farthest point, ambient air temp downstairs, ambient air temp upstairs in various room, there are others on here that can tell you if you are getting the best.
Return Vents and Air Handler Question hifiman HVAC 7 04-27-2012 07:44 AM
Closing off HVAC return and supply vents Kulingar HVAC 6 11-15-2011 10:22 AM
Distance between HVAC supply and return vents atlantatd HVAC 4 04-13-2011 09:30 PM
Oversized Furnace, Undersized Return Air vents and Low Heat Output.... ?? LabRat0116 HVAC 4 10-04-2010 09:53 PM
Where to put Return air vents in basement sj22 HVAC 12 06-08-2009 10:35 AM
