Air Return In Unheated Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 01:57 AM   #1
Air return in unheated basement
I've discovered that there is a return air duct opening in the ceiling of an unfinished, unheated basement. This is connected to a furnace/AC in the attic that serves the second floor. It seems counterproductive to be drawing very cold air into the system. Also, the gas water heater and boiler for first floor heat are down there so am concerned that the draft may interfere with their operation. Would it make more sense to block off the basement opening and replace it with one above on the first or second floor? The basement return is the only opening on that duct branch.
olivedal is offline   Reply With Quote
Return air for the basement swoop HVAC 4 01-18-2011 04:14 AM
HEating vents and cold air return in basement hazey313 Building & Construction 3 09-30-2010 08:55 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement return air ducting - flex or metal? BasementVirgin HVAC 5 10-29-2009 12:01 PM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
