Air Return Plenum Fasteners - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2013, 07:43 AM   #1
Air Return Plenum fasteners
Yesterday, while changing my in-ceiling air filter, I noticed something odd on the inside of my air return plenum box. Located towards the bottom of the plenum box are nails with green plastic caps, two nails on three out of the four sides of the box. Nearly all of the green plastic caps (these look like the same type of fasteners roofers use for the tar paper) are cracked and loose to the touch. A piece of one of the fasteners even pulled right off with no effort. I suspect these plastic caps were compressing the insulated lining at some point, but maybe gave in? The plenum box doesn't appear loose, but the thin black felt-like lining coving the pink insulation panel is torn slightly where each of these cap-nails are present and cracked. I wish I had a picture, but my camera stopped working some time ago. Please help!
segal is offline   Reply With Quote
Old 06-05-2013, 08:00 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by segal View Post
...towards the bottom of the plenum box are nails with green plastic caps, two nails on three out of the four sides of the box.
...the thin black felt-like lining covering the pink insulation panel is torn slightly where each of these cap-nails are present and cracked.
Take a look here --> LINK
Identify which type of duct insulation installation pins you need help with. Then you can shop for them.
You can also use foil tape to secure/repair torn insulation.
FOIL tape (not duct tape). Get some.
plenum return damper signalnc HVAC 0 05-30-2013 09:13 AM
How to use fiberboard as a duct return Scooby333 HVAC 1 03-17-2013 04:29 PM
Help with Return Plenum Solution ChrisDIY HVAC 3 10-31-2011 09:06 AM
return plenum and a drywalled basement ceiling 06bluez HVAC 1 11-25-2009 04:41 PM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 10:20 AM
