Air Return In Old House - HVAC - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 08:11 PM   #1
air return in old house
recently bought a house thats 50 year old.. its in great shape but during the inspection i was told the cold air return has exposed studs.. which is no longer the way they do things.. my bed room light swich is in the same air space.. im planing on changing the light swich to a dimmer and rewire it to 3 wire so the fan and light and have thier own dimmer. this will require me to put in a 2gang box because because the existing light swich is a dual swich and control a outside light as well.. i can rewire it no problem..but when i change something i would like it to be up to code.. my question is should i seal up the walls inside the air return after..im a small person i can get in there and do the work.. what is the best solution and material for the job.. thanks in advance
gezzuzz is offline   Reply With Quote
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 03:57 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 02:39 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
