Air Not Blowing Out Of Vents When A/C On - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 11:24 PM   #1
Air not blowing out of vents when A/C on
I just installed a new digital thermostat because my old one seemed to not shut off the heat or air conditioner properly. I can set the heater to come on and it seems to work fine but when I turn on the A/C (set it about 5 degrees below the current temperature) the outside unit turns on and keeps running and cool air seems to come out of the intake below the A/C unit but it does not come out of the vents. I am not sure how much information I should provide but I will try to answer any questions about the system I can. I appreciate any help I can get.
kevin82 is offline   Reply With Quote
Old 01-05-2009, 08:11 AM   #2
An old Tradesmen
Rewards Points: 6,560
Did you hook a wire to the G terminal on the thermostat.
Needs to be hooked for A/C.
Also, make sure you don't have any of the wires insulation under teh terminals screw.
Old 01-05-2009, 10:14 AM   #3
I have a blue wire hooked into the G terminal and all wire insulation seems to be clear of the terminals. If it helps I have a 4 wire system white wire in W, yellow wire in Y, red wire in Rh, and blue wire in G. I hooked it up just like the old thermostat was except for a jumper wire from Rh to Rc. The directions for the new thermostat (a ritetemp 6022) didn't mention including this jumper wire so I assumed it wasn't needed? Thank you for your help with this.
Old 01-05-2009, 11:58 AM   #4
You will need that jumper from RH to RC before the ac will work.
SKIP4661 is offline   Reply With Quote
Old 01-05-2009, 12:21 PM   #5
An old Tradesmen
Yep.
You need that jumper.
Old 01-05-2009, 12:44 PM   #6
Alright I was wondering if that would be the problem but I thought the separate jumper terminal next to the circuit terminals would have taken care of that? Please let me know if I am wrong and I will try running a jumper wire from Rh to Rc. I appreciate everyone's help with this.
Old 01-05-2009, 12:47 PM   #7
An old Tradesmen
If it has a factory jumper, that should take care of it.
Sometimes, the factory doesn't tighten that screw.
Check it.
Old 01-05-2009, 02:43 PM   #8
I am going to check that everything is tight when I get home from work. I will let you know if that fixes it.
Old 01-05-2009, 09:13 PM   #9
I took everything off and connected it again and everything is running well. Thank you both for the help.
Removing some vents rdmccaw HVAC 4 10-22-2008 02:00 PM
Big trouble with gable vents! Beth777 Building & Construction 9 08-11-2008 08:32 AM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 06:02 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 10:47 AM
Rookie Needs Help - No AC Blowing Thru Vents? BDPNA HVAC 13 05-15-2007 08:01 AM
