Air Leaks Around Duct (boot) Into House. - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 02:57 PM   #1
Air leaks around duct (boot) into house.
I just had two separate heating systems install, one for the master suite (a 2-ton) and a (3 ton) system for the rest of the house. My question....IT Does not appear that the "boot" that is cut into the floors are seal and they are very cold and does not seem insulated up into the floor; should they be and with what? I informed the installer that i could see day light and he painted some gray mesh around the inside coming into the house floors. Is this enough and will it stop the cold and heat leaks? If not what should be done?
Thanks for your help....VANESSA
VANESSASEA is offline   Reply With Quote
Old 03-04-2012, 05:01 PM   #2
An old Tradesmen
Rewards Points: 6,112
Please don't type in all cps, thank you. I fixed that, so its not hard on our members eyes.
Is the duct work in a crawlspace.
Using flex duct for return. lakeresident HVAC 3 11-14-2011 10:56 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
Do I need to insulate duct in the a chase in the middle of the house vdu HVAC 3 11-15-2009 02:53 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
