Air Leak On Beckett Burner - HVAC - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 01:43 PM   #1
Question
Air leak on Beckett Burner
Hey all,
I have a Beckett AFII burner that is leaking air. The air seems to be coming from between the housing assembly and the igniter, where the wires run through. I have a picture:
http://i.imgur.com/v0zwc.png
Link: http://imgur.com/v0zwc
The red box is where the leak appears to be (under the igniter), and the arrows is where the air is coming out. I assume there was a gasket between the igniter and housing assembly, but I'm not sure. The burner still apparently runs OK, and I don't smell any funny smells. However, I would also assume the air-to-fuel mixture isn't correct anymore... any suggestions? Getting a technician to come out is so expensive, especially when the burner still seems to work!
Phr00t is offline   Reply With Quote
Old 05-21-2011, 04:36 PM   #2
TRY THIS WEB SITE YOU MAY BE ABLE TO CALL TECH SUPPORT WITH THIS QUESTION.
http://www.beckettcorp.com/protect/tech.asp
I BELIEVE THERE WILL BE SOME AIR COMING OUT BUT SHOULD NOT BE EXTREME AIR FLOWING OUT.
Artco is offline   Reply With Quote
Old 05-22-2011, 11:35 AM   #3
I ended up getting some of this:
http://www.acehardware.com/product/i...ductId=1273881
... and I taped up the hole were the wires run through the housing assembly. No more air leak!
EDIT: Thanks Artco for the reply!
beckett oil burner pump problem slacov HVAC 18 10-04-2015 10:13 AM
beckett burner joenick Plumbing 2 10-21-2010 09:06 PM
Beckett Oil burner ricbrk HVAC 1 08-25-2010 08:26 PM
Original problem to beckett burner question.. jmhai HVAC 17 01-14-2010 05:25 PM
Which beckett burner do I need. jmhai HVAC 6 01-11-2010 09:42 PM
