Air Intake- Powered Flow-thru Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 09:15 PM   #1
Rewards Points: 97
air intake- powered flow-thru humidifier
looking to install a honeywell HE360A powered flow-thru humidifier in the basement.
can any one familiar with this unit answer this- does this unit suck outside air (in this case the basement air), or the air from within the duct work?
while the name implies it takes air from with the heating system duct but looking at manual it is not clear where the air intake for unit is.
thanks.
drgkjd is offline   Reply With Quote
Old 02-17-2012, 11:38 PM   #2
thanks.
why would you want to use a power humidifier on a up flow furnace?
dosy777 is offline   Reply With Quote
Old 02-18-2012, 04:37 AM   #3
An old Tradesmen
Rewards Points: 7,816
It only uses air fro inside the duct/plenum.
Old 02-18-2012, 09:18 AM   #4
Rewards Points: 97
thanks
Old 02-20-2012, 09:07 PM   #5
Rewards Points: 97
i am not familiar with the terminology but seems like since the hot air rises from basement to upper lever, it is called up-flow.
are you suggesting a by-pass unit is better?
Humidifier Wiring to HAi Omnistat cipherman HVAC 10 11-09-2014 12:34 AM
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 04:26 PM
Back flow on Humidifier Bypass Scott02 HVAC 0 01-27-2011 04:46 PM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 07:42 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
