Air Handlers Not Staying On. - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 05:17 PM   #1
Air Handlers not staying on.
We have two air handlers and two condenser units that run on one thermostat and when I put the system in cool the air handlers are fluctuating on and off but the condenser units are staying on, and when I switch it back off the air handlers don't stop fluctuating until I turn off the air handler's breaker off. What could be the problem?
tyhorstman is offline   Reply With Quote
Old 05-01-2012, 10:04 PM   #2
Rewards Points: 616
I am afraid from that description it could be anything..... more details please....
carmon is offline   Reply With Quote
Old 05-01-2012, 10:24 PM   #3
Given that the air handlers always do the same thing, it seems likely they aren't wired correctly (given that there are 2, they probably didn't both break identically). I'd look back over wires between air handlers and condensers, make sure you didn't cross between the two, voltages are correct, etc.
I'm assuming this is a new system, never properly operating. Am I correct? Good luck.
casey2u is offline   Reply With Quote
Old 05-01-2012, 11:08 PM   #4
No actually it's ran in this configuration for years, but now as soon as the blowers spool up they kick of and begin to spool up again. It doesn't do it all the time though. We called an hvac tech out and of course it ran fine while he was there but, he checked over all the wiring but didn't find anything, he replaced the thermostat batteries and said if it does it again it might need a new thermostat.
Old 05-01-2012, 11:16 PM   #5
Rewards Points: 616
spool up ........fishing time.... sorry i do not get it......
Old 05-02-2012, 12:03 AM   #6
Hmm. I wouldn't think it's the thermostat, but it could be: if they were stuck on fan for example. You're saying the air handlers do their cycling thing all the time, forever, until you've switched them off? The fact that the thermostat properly controls the condensors (or at least turns them off) implies that it's not the root cause, to me. Has there been any other electrical work done in the house recently?
Old 05-02-2012, 04:12 AM   #7
An old Tradesmen
Rewards Points: 6,824
Guessing this is a twinned system. Was a twinning control use?
Old 05-02-2012, 08:28 AM   #8
Sorry, I mean come up to speed.
Yes
Old 05-02-2012, 08:34 AM   #9
Sometimes the blowers start just fine but most of the time they continually cycle on and off, and no we haven't had any major electrical work. Could it be the 24 volt transformer? The reason I ask is because while it's cycle on and off if you turn the system back off the blowers don't stop, you have to disconnect power.
Old 05-02-2012, 10:34 AM   #10
I can't see how, and again, the fact that the condensors work properly on/off implies that the thermostat/transformer is ok... to me.
Old 05-02-2012, 10:44 AM   #11
Does the Blower fan have a start capacitor?
Old 05-02-2012, 03:43 PM   #12
An old Tradesmen
Post brand and model number of the twinning control. it could be the twinning control, or one of the sensors that is used to determine if both fans are running.
Old 05-03-2012, 03:03 PM   #13
Thanks for all the help. The evaporator drain is clogged so the evaporator is leaking and I think it has gotten the twinning control wet. The system is shutdown. We've called out a hvac tech and we're going to have him look into it.
Older (late 80's) Carrier burners not staying lit FSHNROD HVAC 5 01-13-2011 07:04 AM
Air Handlers - New Home JackOfAllTrades HVAC 4 07-16-2010 05:23 PM
What kind of air handlers to use with heat pump euwilson HVAC 1 06-27-2010 11:10 AM
2 Air Handlers 1 Thermostat SemperDIY HVAC 3 01-03-2009 05:30 PM
wiring for air handlers? 737Pilot HVAC 8 09-30-2008 09:33 PM
