Air Handlers - New Home - HVAC - DIY Chatroom Home Improvement Forum
Old 07-15-2010, 10:22 PM   #1
I have a new Standard Pacific home and I have 3 air handlers in the attic (one for each level + the bonus room).
I went up to check on them (115F outside) and you won't believe what I found.
Air Handler #1 - It has 1 drain pipe going outside and to the left of that drain pipe is a capped line. Drain is dripping water outside and all seems OK. But there is NO open line to the catch pan, it has been capped off. Which doesn't seem right with me. Because if the line going outside backs up. Where is the water going to go?
Air Handler #2 - It has 1 drain pipe going outside and to the left of that drain pipe it is an OPEN line that faces down onto the catch pan, and the pan is dry. But here is the kicker. When the AC turns on - COLD AIR comes out of that open line. Cold air also comes out of a PVC tube that is facing up and appears to be a vent of some sort.
Air Handler #3 - Has the same setup & problems as AH#2 but it also drips water out of that open line/vent ONTO THE CATCH PAN. I have water on the catch pan.
WHAT THE HECK? Did they plumb it all wrong? Need help!
JackOfAllTrades is offline   Reply With Quote
Old 07-15-2010, 11:32 PM   #2
An old Tradesmen
Rewards Points: 6,590
Unit 3 may not have enough pitch on the drain line. or its already restricted somewhere.
Common to cap the secondary drain on A/Cs installed on furnaces. If you don't. You get cold air blowing out.
Old 07-16-2010, 10:14 AM   #3
Rewards Points: 338
that's an interesting observation i noticed too. i have two furnaces and both my old air handlers were both capped on the secondary drain. on the new ones, they aren't and yes some cold air blows out of them. if the secondary drain is capped, but a secondary drain pan is installed, what is the point? how will water ever get into the secondary pan if the primary drain backs up?
NitroNate is offline   Reply With Quote
Old 07-16-2010, 12:11 PM   #4
An old Tradesmen
The primary should have a trap, and a vent on the discharge side of the trap.
Then if the drain backs up. The water flows out of the vent, and into the secondary pan.
Old 07-16-2010, 06:23 PM   #5
Or they make a nifty little float switch that screws right into the secondary. I believe it's the same company that makes the EZ trap.
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 09:15 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
Home Addition destepan Building & Construction 6 12-05-2007 01:28 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
