Air Handler Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2008, 09:22 AM   #1
Air Handler won't shut off
I have an Amana air handler which has been installed for a few years. The fan blower will not turn off. I have checked the thermostat settings, disconnected the thermostat, turned off/on the power to the air handler( it comes back on), and after all of this, the blower still won't turn off. I am a little rusty troubleshooting circuits, could the problem be the electronic blower time delay relay? Thanks.
Perk is offline   Reply With Quote
Old 11-11-2008, 10:18 PM   #2
yes and it most likely is if you can figure out which wires perform the delay function you can just cut them and it will operate as a normal relay
kennzz05 is offline   Reply With Quote
Old 11-12-2008, 05:20 PM   #3
Thanks, that was my thought, now for some trial and error...
Tags
air handler
Community water shut off zevon Plumbing 14 10-03-2008 07:16 AM
Toilet to Go won't shut off Evildad Plumbing 4 09-28-2008 12:26 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 12:44 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
