Old 11-08-2012, 08:41 AM   #1
Air handler will not come on
I have a First Co. Air Handler Model 30HBXB-HW and it will not turn on this season. I actually have 2 of them and the down stairs one comes on but the upstairs one does not Any Help would be greatly appreciated......
stvktchn is offline   Reply With Quote
Old 11-08-2012, 10:21 AM   #2
Air handler typically has auxiliary/emergency heat strips (resistive electric heat elements) that are energized by thermostat when heat demand is high, when you manually select emergency heat, or by heat pump during its defrost cycles. Some heat pumps have an outside thermostat to shut unit down during low temperatures, during which time you are totally dependent on auxiliary/emergency heat from source other than heat pump. Circuit for air handler may include more than one breaker. Circuits for air handlers with heat strips generally have very large amperage requirements, more than the external heat pump itself. Breakers deteriorate over time, reducing capacity. There may be an issue in the air handler itself, including internal heat strips, fan, or wiring. Due to the high amperage/voltages, the potential for damage/fire/injury is great. if you don't know what you are doing you should consult an expert
jacklance is offline   Reply With Quote
Old 11-08-2012, 10:56 PM   #3
I should have said this one is hydronic, Time to get a meter out and see whats not working I guess....
Old 11-11-2012, 01:35 PM   #4
All Fixed found a neutral that was not in place on the computer board. put it back on and we are up and running. THank you for your help
Do I really need the air handler filter? Flt_Simulation HVAC 2 09-17-2012 11:38 AM
Return Vents and Air Handler Question hifiman HVAC 7 04-27-2012 07:44 AM
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 01:55 PM
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 28 03-31-2012 11:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
