Air Handler Will Not Blow - HVAC - DIY Chatroom Home Improvement Forum
Old 04-29-2010, 09:09 PM   #1
Air Handler will not blow
FY4ANF048 Carrier Air handler will not blow. I opened it up and the top of the coils are iced over. I turned off the AC and the ice leaves.
I have a sticker on the unit that says "Attention, Condensate shut off switch. If unit is not operating properly, check for condensate in drain pan or trey.
I cannot find this tray or pan.
Any help appreciated. It is about to get very hot here in SW FL and I have 4 kids. Thanks!
Holysmoke99 is offline   Reply With Quote
Old 04-30-2010, 05:52 AM   #2
An old Tradesmen
Rewards Points: 6,112
If the coil was frozen. Its generally not that switch, since that switch shuts off the A/C. And you wouldn't have seen any change when you turned off the unit.
Check air filter. Check blower motor. Check if bottom of coil is dirty.
The Following User Says Thank You to beenthere For This Useful Post:
Holysmoke99 (04-30-2010)
Old 04-30-2010, 08:13 AM   #3
ya, that makes sense. Air filter is new, bottom of coil needs cleaned. How do I check blower motor and what am I looking for? thanks
Old 04-30-2010, 03:10 PM   #4
try operating the fan in the on position at the thermostat see if it runs
kennzz05 is offline   Reply With Quote
Old 04-30-2010, 03:18 PM   #5
all is running smoothly again, thanks
holysmoke is offline   Reply With Quote
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 06:52 AM
Space Pac Air Handler Wiring--208-230/60/1 Volts metal121 Electrical 4 05-05-2009 11:20 AM
Air Handler flow problems dewalt HVAC 12 04-30-2009 08:59 AM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 10:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
