Air Handler Transformer Gone Bad - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 11:11 AM   #1
Exclamation
Air handler transformer gone bad
hello guys,
I'm new to the blog so please take is easy on me . Let me start with a little background on my furnace problem. I have an airhandler made by "First Company" model 30VAQ3. The first time i started noticing a problem was last year when the heater wont shut off on its own even when the thermostat reached its desired temp. i let it go bcoz it was the end of winter and thought its the thermostat and will change it next year. Another reason for delaying it was bcoz the AC turned on and off without any problem controlled by the same thermostat. Well this Year the same problem started happening when i turned the heater back on and finally on Friday i shut the unit off to look at the internals and now it wont turn on again. Called a repair guy and he said transformer has gone bad and wanted to charge me 300$ for the whole deal. i said no thanks and bought a 20 $ transformer from the store and getting ready to hook it up. My concern is that something made it go bad and i suspect its the wiring from the thermostat. Another piece of info is that i did replace the thermostat but that did not fix the problem in the beginning of this cold season. Please advice me on whether my suspicion of the wiring could be correct and how to test this theory.
Thanks in advance for your help.
flyinhorse is offline   Reply With Quote
Old 12-20-2010, 11:52 AM   #2
Add a 3 or 5 amp fuse on the 24V side of the transformer, if the fuse blows replace the thermostat wire, Make sure you have the right Milliamp transformer for your system
Swift is offline   Reply With Quote
Old 12-20-2010, 12:04 PM   #3
Are there any how to videos on this and i verified the power requirements on both transformers and they matched.
Old 12-20-2010, 01:02 PM   #4
http://www.youtube.com/watch?v=M5y2F...eature=related
http://www.youtube.com/watch?v=RRnG-...eature=related
Old 12-20-2010, 06:38 PM   #5
JJboy's Avatar
POWER OFF
1-Replace the transformer
2-Disconnect all wires from Thermostat
3-Disconnect all wires from board control at Air Handler
4-On the Air Handler connect together all the wires combinations.
5-On the Thermostat, with a multimeter start doing continuity test.
If you find a short or open wire you found problem.
JJboy is offline   Reply With Quote
Tags
air handler , furnace , heating , transformer
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 01:07 AM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 11:10 AM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 08:21 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
