Air Handler Support - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 07:17 AM   #1
Rewards Points: 280
Air Handler Support
Can an air handler be saftely suspended from the crawlspace side floor joists?
Mine is off the ground by about two inches on small bricks. I want to provide a better thermal break from ground temperatures during the Winter.
Any suggestions?
Earnie is offline   Reply With Quote
Old 07-19-2010, 07:03 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
Not much thermal conductivity thru small bricks. The air handler is insulated internally. Better off to insulate the crawlspace with building code approved insulation and methods. Check your local codes.
Old 07-20-2010, 07:27 AM   #3
Rewards Points: 280
Yes, but I suspect I have an air handler cabinet designed for interior (conditioned space) installation and not exterior (un-conditioned space) installation. There is insulation in the cabinet but not to level it should be.
So back to my question. Can the air handler be supported from the floor joists vs sitting on the ground?
Old 07-20-2010, 07:37 AM   #4
An old Tradesmen
Rewards Points: 7,306
From the floor joist, yes.
Old 07-20-2010, 05:08 PM   #5
Hvac Pro
yuri's Avatar
You may be able to add some of that foiled backed insulation to it to improve it. HDepot may have it.
Best Method for attaching decking lateral support getzjd Building & Construction 2 05-19-2010 06:45 AM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 05:48 AM
Sealing Air Handler To Support Box? nomad943 HVAC 3 05-30-2009 07:25 PM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
