Air Handler Smell Through Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 02:57 PM   #1
Air handler smell through vents
Hello everyone,
I own a Goodman ARUF049-00A-1B air handler which I've started having problems with this week.
A couple nights ago, I awoke to the smell of something burning through the A/C vents. I noticed that the airhandler was not blowing even though the compressor outside was on. I turned off the A/C at that point to be on the safe side.
The next day, I turned it back on. I could hear the compressor turn on outside. This time, the blower turn on as well. However, after about a minute, I started hearing a rhythmic whining sound coming from the air handler. The whining subsided...but I also noticed the fan began to slow down. After about 5 minutes the fan had come to a full stop even though the thermostat had not reached the temperature I set. I shut off the A/C and a few seconds later, the "burn smell" came through the vents again.
Does anyone know what it most-likely could be? The unit is about 7yrs old.
Thanks everyone!
joshjustin is offline   Reply With Quote
Old 10-16-2012, 03:02 PM   #2
JJboy's Avatar
blower motor or capacitor
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
joecaption (10-16-2012)
Old 10-16-2012, 06:27 PM   #3
Yep. If the blower motor got hot enough to smell like something burning it's shot. Replace the motor and capacitor at the same time.
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Another bad smell in vents. Kitty Litter Odor but no cats!? Wes-P General DIY Discussions 18 11-11-2012 12:58 PM
Return Vents and Air Handler Question hifiman HVAC 7 04-27-2012 06:44 AM
Horrible musty smell from vents vln HVAC 6 04-12-2012 09:36 PM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
