Air Handler Run Capacitor - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2011, 09:08 AM   #1
Air handler Run Capacitor
Do I clip off the two extra metal prongs before plugging in?
Dave Frantz is offline   Reply With Quote
Old 12-20-2011, 09:11 AM   #2
biggles's Avatar
no doesn't matter that's just for other applications
The Following User Says Thank You to biggles For This Useful Post:
plummen (12-20-2011)
Old 12-20-2011, 02:51 PM   #3
HVAC Tech/ Browns Fan
Really need to find out why run cap went out. It can be motor going out, plugged filter causing motor to go high amps or even plugged up indoor coil. Run caps go out for reason not always 100% fix
Tator1076 is offline   Reply With Quote
How to replace condensor fan motor? twags HVAC 44 08-27-2015 06:09 PM
Air handler - reverse polarity after changing capacitor ezhomeowner HVAC 8 07-27-2011 09:13 AM
run capacitor blew up caught fire in AC unit. saltshaker30 HVAC 2 07-01-2010 10:08 PM
Condenser motor and Capacitor confusion ryanru HVAC 5 06-26-2010 01:25 PM
Air Handler Motor Wiring brando1118 HVAC 13 06-18-2010 12:42 PM
