Air Handler - Reverse Polarity After Changing Capacitor - HVAC - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 09:04 AM   #1
Air handler - reverse polarity after changing capacitor
Air handler was blowing warm air. Changed fuses and capacitor- (on outside unit) everything seemed to be working nicely. - for a little while-
Now neither outside nor inside turns on, I took cover off handler and led flashes continuously meaning polarity reversed.
flipped C wires on capacitor even re-installed old (bad capacitor) but no luck Air handler not turning on..
what do I do?
ezhomeowner is offline   Reply With Quote
Old 07-26-2011, 10:37 AM   #2
Experienced
Jackofall1's Avatar
Welcome ezhomeowner, to the best darn DIY'r site on the web.
In order for anyone to help you diagnos your situation you will need to post a model number(s) of the unit you are referring to.
Mark
Old 07-26-2011, 01:04 PM   #3
Payne PG9MAA024060* Furnace
This is the air handler. It is in the attic, the compressor is out side. I changed the capacitor. took old one to supply store and they gave me new one., New one is oval so I could not strap it in so I let it sit on the floor. It still looks perfect but now my air handler stopped working.
Specs
Brand: Payne
Manufacturer: CARRIER CORPORATION
Model Number: PG9MAA024060*
Fuel: Liquefied Petroleum Gases and Natural Gas
Input Capacity: 60,000 BTUH
Output Capacity: 56,000 BTUH
Efficiency: 91.5% AFUE
Energy Star Certified: Yes
Air Flow Configuration: Down
Electrical Phase: Single-phase
Combustion Type: Condensing
Old 07-26-2011, 02:15 PM   #4
I have 2 Short and 4 long flashes -
I went and looked again at the lights blinking and noticed that this corresponds to a code 24 meaning Secondary Voltage Fuse is Open..
Not sure how check this...
Old 07-26-2011, 02:51 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
there is a purple 3 amp GM plastic auto fuse on the circuit board.
The Following User Says Thank You to yuri For This Useful Post:
ezhomeowner (07-26-2011)
Old 07-26-2011, 03:21 PM   #6
Yeah - I found the Fuse !!! -
Little 3 amp fuse... 5 for 3.50 @ the supply store...
Fuse sits on electronic board by blower...
Old 07-26-2011, 03:24 PM   #7
Thanks Yuri !!
I found teh fuse and replaced it.
I guess now I gotta figure out what caused it to blow.. but it rained hard yesterday and we had a local power outage so perhaps the surge when the power cam back blew the fuse.
Old 07-26-2011, 04:05 PM   #8
Hvac Pro
yuri's Avatar
VERY rare that happens. Carefully check the small low voltage wires going to the outdoor unit for fraying/brittle/dog or rodent chewing or deterioration.
Old 07-27-2011, 09:13 AM   #9
It was my capacitor touching the Fan wire relay
The capacitor was oval instead of round since the supply store did not have round.
The metal casing of the "cap" knocked against the brown fan wire ( happened again) when I shut the cover after replacing the fuse and blew the fuse again.
I wrapped the case in electrical tape and used plastic ties to secure the capacitor away from the open wires ends and attach it to totally insulated wires. ( i could not use the cap strap it was just to small for oval)
This seems to be working...
thanks
Air Handler Motor Wiring brando1118 HVAC 13 06-18-2010 12:42 PM
Reverse Polarity scrubby18436572 Electrical 4 04-24-2010 09:53 AM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
Changing reverse osmosis water filters awayeli General DIY Discussions 2 07-05-2008 03:20 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
