Air Handler Part Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 06:09 PM   #1
Air handler part question
Sorry for the improper nomenclature, but this is my problem.
I am replacing my evaporator coil that is connecting to my air handler.
Old coil dimensions are 33.5 x 25 x 12 and all the newer 4 ton evaporator coils are 39 x 25 x 12. The 39 inches wide will not fit in the current layout in the attic. Can I order some sort of angled piece that transitions from my furnace to coil at an angle in order for it to fit?
Thanks for the help!
blarose is offline   Reply With Quote
Old 07-13-2011, 07:03 PM   #2
JJboy's Avatar
You can use flexboard to deal with this space. The most important is replacing the TXV to match condenser .
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-13-2011, 07:51 PM   #3
Hey thanks!
How do I know if I currently have a TXV installed and is it required to have one in the new replacement?
Old 07-13-2011, 08:39 PM   #4
JJboy's Avatar
You have to install a new TXV even it comes with a new coil. The new TXV has to match the condenser specs.
Old 07-13-2011, 08:45 PM   #5
I am getting a 4 ton coil to match my 4 ton condenser.
Even though they are the same tonnage they might not be comparable?
What else do I need to look at?
Old 07-13-2011, 09:43 PM   #6
JJboy's Avatar
if the coil replacement has the same tonnage and seer that's ok. Ask the store guy
Old 07-13-2011, 10:07 PM   #7
Below is the link for the evap coil I am looking at. I can't find a seer rating listed.
http://www.acwholesalers.com/Product...ductCode=11243
My outside unit is Goodman 4 ton CK49-1B
What would I need to purchase to make the two compatible?
Delta tub spout question natwin Plumbing 19 02-17-2013 01:23 PM
Inducer motor; ID on Part: Carrier Part # HC21ZE123A - Cross reference help mtom01 HVAC 10 02-20-2011 06:43 PM
Rafter question mrmarkyt Building & Construction 4 04-08-2009 09:19 PM
AH In Extreme Cold Attic Question Home Air Direct HVAC 6 03-14-2009 09:02 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
