Air Handler Only Works In Manual - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2009, 07:34 PM   #1
Air handler only works in manual
Not having dealt with a/c units before I was wondering if anyone could tell me.....the outside unit seems to be working fine and the handler fan works on manual but not on auto. What voltages shoul I read and where to check to see if the thermostat is working? After i verify the t-stat is working what else should i check?
Jayw is offline   Reply With Quote
Old 06-29-2009, 08:41 PM   #2
Too old to argue with you
The fan switch is either dirty or bad on the thermostat sub-base
30yrhvactech is offline   Reply With Quote
Old 06-30-2009, 01:14 AM   #3
T-stat is the problem..
remcoair is offline   Reply With Quote
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 05:52 AM
Space Pac Air Handler Wiring--208-230/60/1 Volts metal121 Electrical 4 05-05-2009 10:20 AM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
