So here is what I found/did tonight....
First got access to the fins and vacuumed both sides (inlet and discharge) with a brush attachment.
Then sprayed it with some coil cleaner, let it soak, sprayed it with a water bottle.... then repeated... then vacuumed it after if dried
I then removed the blower assembly to try and get the model # of the motor...but it was hidden under hte bracket that goes around it, even tried to disconnect the squirrel cage but it wasnt happening... and I was pressed for time so I jsut took a bunch of photos and hopefully that can identify the model I need (If I need one)
I then put everything back together and verified the voltage to the entire blower assembly, it was about 243.
I then verified the current draw to the motor at about 1.2Amps (well under the 1.7Amp rating on the front of the unit)
Also, someone (Doc?) was talking about checking the ciruit board while different things were being ran to see different speeds or something.... after looking at my system (and talking with an AC Journeyman that the tenant hired to put in the thermostat) there are only to positive connection points (red wire) to the motor, medium and low speed (high speed doesnt have a spade). So it would appear the only way to vary the speed of the fan is manually moving the wire.... but its currently on the highest possible setting....
Unfortunately I had to leave in a hurry before the guy finished putting in the thermostat to try everything out... so I will call her in the AM for an update....
Hopefully the problem is solved, cause Im out of ideas....
Is it bad to replace the motor with a stronger model (possibly higher RPMs) in order to increase the air flow some? Or would that mess up the entire balance of the system....
thanx for all your help...
I think (as a new homeowner) I may have to start hanging around this forum more for all the great advice...
Maybe layoff the Android Forum I normally hang out in
-Danny
