Old 04-08-2012, 09:15 PM   #16
Air handler not pushing enough air
So I got a new Run Cap for $35... which I thought was a fair price till I saw Allied sells it for $8, but thats OK, helping to support my local companies
hooked it up and it seemed a little better...
then I happened to check and saw that the unit still had the same air filter that I installed in september, apparently the renter didnt know you were supposed to change them
when I took off the dirty filter, I got a decent amount of air coming out the vents... so hopefully that was the main issue...
time will tell...
Thanx a ton for all who offered up some ideas and thoughts....
hoping for another 2 years out of the system before I need to replace it
-Danny
dcastillo is offline   Reply With Quote
Old 04-10-2012, 03:09 PM   #17
That wasnt it.....
Question... everyone I have talked to says that when a motor goes bad, it will just stop... never do they slow down... is that true?
I dont want to pay 300 for a motor if thats not the issue....
Next I guess I will try cleaning the evap coils....
from what Ive read, ill start with a shop vac and brush attachment, then maybe some mild dawn soap and water, and rinse it off, then maybe vacuum again...
hopefully that will help
Old 04-10-2012, 06:03 PM   #18
An old Tradesmen
They sometimes run slow, instead of just stopping.
make sue you clean the inlet side, not just the discharge side.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
dcastillo (04-16-2012), plummen (04-10-2012)
Old 04-10-2012, 06:07 PM   #19
would I be correct in assuming the inlet side is the side the air hits first and then cooled off as it goes out the discharge side?
Old 04-10-2012, 06:19 PM   #20
An old Tradesmen
Yep, you got it.
Old 04-10-2012, 06:43 PM   #21
retired elect/hvac/plumb
plummen's Avatar
That wasnt it.....
Most of the time they just stop,but sometimes they just slow down and run real hot in my experiance anyway
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Old 04-10-2012, 06:45 PM   #22
That's good... cause the inlet is the easy side to get to....
Old 04-16-2012, 12:03 PM   #23
Could I check and see if its running slow by reading the current draw to the motor? (with a Clamp meter)
Or is there another way to verify the motor is running at full (proper) speed?
thanx
Danny
Old 04-16-2012, 12:41 PM   #24
ryanxo's Avatar
I have this same issue so I figured I would add my troubleshooting in hopes we can both get this figured out.
You can barely feel any air at all when you put your hand up to the vent.
It doesn't matter if it's on FAN, HEAT, or COOL the air flow coming out of the vents is the same.
I had this problem last year ever since i bought the house and over the winter and cannot seem to get it resolved.
It's a trane XR 11 system. The air handler matches.
It's a 1344 sq foot house, 1 story.
It has 10 flex ducts run off of the main plenum in a spider configuration.
8 are 6 inches and 2 are 4 inches.
- All my duct work is sealed with mastic and foil tape
- I've had the evap coil, and condensor coil cleaned
- the outside fan runs
- inside air handler runs.
- My plenum came made 2 90 degree turns coming out of the air handler so over the winter I modified it and made it a diagonal in hopes that would help... it didn't.
Other than that I'm at a loss of what to do. I've looked into getting in line duct booster fans but they said those are just for if you have 1 or 2 rooms that have low air flow...this is all of them.
Will be payng close attention to this thread to see the results.
ryanxo is offline   Reply With Quote
The Following User Says Thank You to ryanxo For This Useful Post:
Old 04-16-2012, 12:45 PM   #25
I'm Your Huckleberry
thanx
Danny
You can check amperage. Also check the capacitor. Need a meter that reads microfarad (mfd).
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 04-16-2012, 12:54 PM   #26
capacitor is brand new, just installed it.... didnt seem to help...
Thanx
Danny
Old 04-16-2012, 12:58 PM   #27
How's the air flow with the plenum completely off? Does it blow hard? A plenum should be straight, should fit the opening of the rear of the coil perfectly, 3' in length and then you should have the proper sized duct work.
You can check the static pressure (hire someone to do so if need be as you need a magnahelic or a digital manometer) to see how badly the air is being retricted.
Thanks.
Old 04-16-2012, 01:03 PM   #28
Thanx
Danny
Check voltage to the unit ,to and through the board and to the motor. What is it at each spot? Check that amperage draw. Usually when a motor begins to weaken it will pull higher amps as it slows down trying to accomplish the work by use of more power, pulling more amps.
Run windings could be weak.
A big thing when motors fail is lack of proper air flow. The motors require a certain amount of cfm to keep them cool enough to not burn up.
Thanks.
Old 04-16-2012, 01:09 PM   #29
Ill check the current draw and the voltage to the motor next time I get to the rental unit... hopefully tonight...
thanx for the advice.
Danny
Old 04-16-2012, 01:20 PM   #30
ryanxo's Avatar
How hard is hard? When I had it open it didnt blow any harder than a 20 inch box fan from walmart.
The plenum can only be 3 feet in length? Wow. Mines alot longer than that. See pic here:
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 01:55 PM
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 28 03-31-2012 11:48 AM
Air handler leaking kcamnairb HVAC 4 08-17-2011 05:32 PM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 10:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
