Old 04-06-2012, 01:48 PM   #1
Air handler not pushing enough air
As much AC trouble as Ive been having lately, thought it might be smart to actually join a chatroom....
I recent bought a new house and have to rent the old one... thanx to murphy's law, the rental has had multiple AC issues right after starting to rent it...
first the outside fan motor bearings went out and cost me 400 to have fixed... if I was living there I would have taken the time to do it myself, but dont have the luxury since its a rental...
Now, after having some freon added, the air is nice and cold, but there isnt much force...
I climbed into the attic and looked around for leaks, but saw none...
I also noticed the air handler seemed really quite while running compared to what I remember when I lived there...
Could it be the Capacitor, would that stop the motor from running as fast?
Thanx for your help...
Danny
dcastillo is offline   Reply With Quote
Old 04-06-2012, 07:19 PM   #2
An old Tradesmen
Could be the cap, or could be a dirty air filter and or evap coil.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
dcastillo (04-06-2012), plummen (04-06-2012)
Old 04-06-2012, 07:36 PM   #3
Thanx for the reply...
Definitely not the filter... and I assume the coils are fine since two different techs looked at the system and said the look fine...
Hoping its the cap
Old 04-06-2012, 07:56 PM   #4
Missouri Bound's Avatar
Direct drive or belt driven blower? It's possible the belt is loose or worn if the latter. Has the motor been replaced or rewired to run at a lower speed? Lots of variables, sorry. Obstructed intake, bad filter, many different possible causes.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 04-06-2012, 08:01 PM   #5
Direct drive
Set on highest speed
Original motor
Old 04-06-2012, 08:04 PM   #6
If you're sure that your ducts are ok. Then yes it could be a capacitor and a motor. I would replace the capacitor since it's cheap. It could also be that the tech reduced the cooling speed when he was there. Try the capacitor first. If you have a meter, then you can know for sure. If you have one let me know and I will show you
Mr.HVAC is offline   Reply With Quote
The Following User Says Thank You to Mr.HVAC For This Useful Post:
Old 04-06-2012, 08:10 PM   #7
I have one... doesn't do capacitance though... but I can check it for open or short....
Now I just need to find a local place open tomorrow.
Old 04-06-2012, 08:15 PM   #8
An old Tradesmen
Many techs look at one side of the coil only.
The Following User Says Thank You to beenthere For This Useful Post:
Old 04-06-2012, 08:23 PM   #9
You can check it with an ohmmeter...preferably an analog meter. At 1K it should move to 0, then swing to infinity.
Old 04-06-2012, 11:24 PM   #10
retired elect/hvac/plumb
plummen's Avatar
When the guy was replacing the bearings on squirrel cage could he have adjusted the pulley on motor slowing it down?
Could it just be that the motor sounds quieter now with new bearings in squirrel cage?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following 2 Users Say Thank You to plummen For This Useful Post:
dcastillo (04-07-2012), Missouri Bound (04-06-2012)
Old 04-07-2012, 05:34 AM   #11
An old Tradesmen
Hoping its the cap
They may have only looked at the discharge/fan side of the A/C coil. may techs don't look at both sides of the coil.
Could also be that they wired it to run on low speed by mistake.
Old 04-07-2012, 06:08 AM   #12
Sorry for the confusion...but it was the outside motor that was replaced, the inside unit hasn't been touched by the techs, only inspected.
Thanx
The Following User Says Thank You to dcastillo For This Useful Post:
plummen (04-07-2012)
Old 04-07-2012, 06:30 AM   #13
An old Tradesmen
Could have loose insulation in the blower compartment, that is blocking air flow.
Old 04-07-2012, 06:56 AM   #14
to check that I would need to remove the blower and look up, right?
Old 04-07-2012, 07:38 AM   #15
An old Tradesmen
Is it a furnace with A/C coil on top of furnace? Or an air handler.
It can be very hard to see the inlet side of the evap coil, if your looking up from the bottom of the furnace, but it is possible on 80% efficient furnaces.
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 01:55 PM
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 28 03-31-2012 11:48 AM
Air handler leaking kcamnairb HVAC 4 08-17-2011 05:32 PM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 10:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
